grandtorino Posted August 25, 2015 Report Posted August 25, 2015 3.1, 4sp auto, 92k miles. I'd like to get this chip from WOT-tech. Does anyone have any experience with these? Does a 2.25" pipe with a glasspack as a resonator and a magnaflow seem like a good idea? Quote
Psych0matt Posted August 25, 2015 Report Posted August 25, 2015 I have lots of visual mods you could do, but there's only a few engine mods to do. A 25 year old 3..1 isn't gonna be all that fast. Pics? I have magnaflows on my 3.4 and it sounds pretty good, considering they're hard to make sound good. 3.1s are easy to make sound mean (if running good) grandtorino 1 Quote
grandtorino Posted August 26, 2015 Author Report Posted August 26, 2015 Thanks so far. I'm not looking to race this, I just want maybe 10-15hp for under a couple hundred. Have any videos of your 3.4 sound? Quote
Psych0matt Posted August 26, 2015 Report Posted August 26, 2015 http://s87.photobucket.com/user/Psych0matt/media/IMG_0211.mp4.html But the 3.4 and the 3.1 sound different (I'd say in most cases the 3.1 sounds better, but I love mine). This was also brand new so it's subtled down a bit As for engine stuff, start with a full tune up, fresh oil, etc. then make sure everything is working properly and that you have no codes. Then you can do things such as a k&n filter or cold air intake, polyurethane dog bone bushings, underdrive pulley (if you can find one), performance chip, etc. these are where I'd start looking, but I've had little to no sleep in the last few days so I'm missing some I'm sure Quote
movielover40 Posted August 26, 2015 Report Posted August 26, 2015 With some exhaust mods and a K & N should give you what your looking for. As long as it sounds mean that's a big step.... Psych0matt 1 Quote
19Cutlass94 Posted August 28, 2015 Report Posted August 28, 2015 The downpipe will help for sure. Mine was a huge improvement. Oh and WOT-Tech products, fucking awesome. That's the only place I buy from. My motor put down some nice numbers, especially since the tune wasn't done and it was on log manifolds. But yes, WOT-Tech chip will help out. Quote
grandtorino Posted August 29, 2015 Author Report Posted August 29, 2015 Thanks for the replies so far. What should I do with the EGR? Plug it and hope for no codes? Quote
jman093 Posted August 30, 2015 Report Posted August 30, 2015 Thanks for the replies so far. What should I do with the EGR? Plug it and hope for no codes? Unhooking EGR will set a code and will not gain any power. Only emission device that hurts power is the catalytic converter. Quote
Schurkey Posted September 4, 2015 Report Posted September 4, 2015 Unhooking EGR will set a code and will not gain any power. Only emission device that hurts power is the catalytic converter. The original GM pellet-style converters were pretty restrictive, and gave cats a bad reputation. The newer, honeycomb/monolithic converters are not nearly as bad. If the converter is original, it may be partially-plugged or otherwise damaged/worn out. The FIRST thing that needs to be done is a comprehensive tune-up including combustion chamber sealing diagnosis and emissions-control diagnosis. There's no point in looking for "extra" horsepower if the engine isn't making rated power due to wear in the rings, timing chain, cam lobes, poor valve sealing, or because of throttle body/intake manifold/port deposits. All the sensors need to be sending appropriate data to the ECM. Quote
