Need help fi ding turbo rebuild kit or replace turbo!
Need help finding Turbo rebuild kit or replacement turbo!
1990 Pontiac Grand Prix McLaren 3.1L LG5 turbo v6.
Link to engine and turbo info:
http://www.v6z24.com/specs/31turbo
This link is to a rebuild kit, Will this work? If not, what will?
http://gpopshop.com/t2-t25-and-t28-rebild-kits/
(Should I go dynamic or carbon seal?)
More info about my turbo:
ASC Part Number: V24X82467BXXX
Manufacture: Garrett AiResearch
Version: TB02528
Cooling: Water and Oil
Lubrication oil flow: 1.2 L/m SAE 30, 90Degrees C, 2.75 Bar
Bearing: Floating sleeve
Turbo Complete Part number: 465939-2X
CHRA Number: 431876-29
Compressor housing casting number: M24
Compressor A/R: .80
Compressor wheel trim: 70
Compressor wheel diameter Ind/Exd: 1.69â€/2.02â€
Compressor flow: 29 lbs/Min
Turbine housing casting number: M4
Turbine A/R: .68
Turbine wheel trim: 62
Turbine wheel diameter: 1.64â€/2.09â€
Wastegate: Internal, vacuum/pressure actuated
  • 2 weeks later...
