GrandRegal Posted August 6, 2015 Report Posted August 6, 2015 Hi guys, I recently purchased a 1995 GTP with the LQ1 and 4t-60e. The car sounds like it has a bad exhaust leak but I noticed the noise is only present in drive gears and worse under acceleration. I can rev it park or neutral and there is no exhaust leak sound. The trans shifts fine and fluid is clean but the noise is very loud and I would like to fix this before I need a new trans. Would this be a torque converter or flex plate problem? Any insight would be helpful. Thank you! - John Quote
GrandRegal Posted August 7, 2015 Author Report Posted August 7, 2015 Added video In drive parking brake set: https://youtu.be/hrb42gOaL-c Acceleration: https://youtu.be/tQYCuW7d8XM Quote
