Temp blend door location-98 gtp
Hi, just wanting to know where the temp blend door actuator is on a 98 gtp with auto climate control?
If you're having a problem with one side of the car a dramatically different temp than the other side of the car, you'd be looking at a failed actuator.  They're under the dash, almost exactly in the center of the car for the left one, a bit more to the right for the passenger side.
