Ok found a turbo, gimme help
Ok my friend has a 1991 TSi Talon and he is replacing the turbo. 50$ and its mine. now itd need to be rebuilt(200$?), but would it be a good size etc for my car? thatnks
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Aaron with a turbo car!!!
Motor #2 coming soon! Good thing your Daddy has deep pockets!!! :roll:
Aaron, i don't think you need a turbo. Why don't you just drop about $3000 into the engine, you should be set.
come on guys!!! give the boy a chance
IMO that turbo would be to small. it was built for a 2.0 and your running a 3.4 so there would be a cfm air requirement problem.
i would like to see what a 3.4 turbo 5speed would produce!! :D
ofcourse within reason. at that motor age dont do more then 8psi!!! keep well within safe operation to ensure endurence and long life of the motor.
small turbo + big engine = turbo overspool = turbo seizing and/or coming apart. Not good either way. Get something that is more fitting to the car.
- Justin
what if i got a wastegate? isnt that supposed to prevent overspool???
thanks for the help, i doubt ill take hiim up on it.
that motor age huh??? wow, i thought 1200 miles was nothin. and also, the guy who built the motor said hed still warrenty it with boost, as long as i didnt exceed 14psi.
and my dad doesnt have deep pockets--i am paying every bit of the $3000 rebuild and i already paid for the car itself. well half, that was the deal.
If it came out of a 5 spd, what you have yourself is a 14b. If it came out of an automatic, it's a 13g and propably too small. Here's a link to some common turbo charger flow maps. http://www.taboospeedshop.com/turbomaps.htm
The 14b is bigger than a t25 (stock tgp turbo) and smaller than a t28/16g. Depending on your goals, it may be enough turbo for you.
Hey, at least he's not talking about N²O...
quote]
ENSURE!! Pick up a frickin dictionary.
suck-it-bitch. :lol:
if you havent figured out yet i dont care to much for proper spelling when i post.
Aaron what i mean is dont over boost your motor and run the life out of it in a few short years. Make that thing last 10 or 20years, not just 2 or 3.
I was talking to Aaron. He thinks you are saying that his engine can't handle a Turbo. You are saying that a turbo will cause the engine to not last as long.
Sure his engine can handle a turbo, you just cant be too aggressive with the boost.
I'm sure he'd be fine with 6-7 or possibly 8 psi, intercooled of course.
Aaron are you sure you can handle a turbo setup? I hope you are, because even if you know what you're doing there's going to be a substantial amount of downtime with your car.
Guest TurboSedan
time for a 2nd car :) i bought my GTS because of downtime with my Cutlass while i'm swapping in my TGP motor & Getrag 282. only $300 too :wink:
altho sometimes i think i actually like my GTS more than my CS :oops:
joshua
I know that feeling... :?
Aaron, if you really want to put something in action, you've got to get a hold of TimG and RedZMonte.
If you provide the hardware, I'm willing to bet those two will get it together for a couple cases of FoCo brew.
- Erik
those motor bays on a z34 are very tight man, u will have to do a lot of relocating just to fit the pipes for ur turbo and intercooler..
ud have to rip everything apart to put it all in ne way, so save urself the trouble, and have ur cylinders borred out, port and polish, and other engine overhaul processes
