Stealing cruise control
I'm taking parts off my '95 GPSE donor car to put on my less well equipped '95 GPSE. What must I be sure to take to make the cruise control works beyond the control stem and actuater box under the hood? And will I find a plug in place for the extra controls on the stem? Also, is there an easy way to get the trunk remote control button out?
Make sure to hook up the brake vacuum dump line. When you hit the brakes the cruise cuts off, and if the dump line is not hooked up the cruise will not work. I can't remember, so you might want to look at a diagram for the cruise/brake pedal area.
