TreySr Posted June 7, 2015 Report Posted June 7, 2015 Hello all, I am wondering if anyone can direct me to where the rear power window fuse/relays are? I knew that the passenger side rear windows motor was probably on its way out (it was going up and down slowly), the drivers side rear window operated very smoothly...now all of a sudden neither window will go down no matter if I push the main controls near the drivers seat or the controls for each window in the backseat...I'm not sure what the issue could be...Iocated the fuse panel (inside the glove box) and also both fuse panels underneath the hood, however, I am not seeing anything in regards to the rear power windows. Is there any other place that there may be a fuse box located? When I push the buttons from the drivers seat all I seem to hear is a "clicking" sound and that's it...I'm sure that both motors couldn't have just gone out at the same time without warning...am I missing something? Thanks in advance. Trey Quote
Nas Escobar Posted June 7, 2015 Report Posted June 7, 2015 Power window breaker (it's a 30 amp breaker, but you can use a fuse in place of it) is in the passenger' side kick panel. You have to take off the cover underneath the dash and you'll find the chime module along with the power windows and power seat breakers there. I can take a pic of mine if you want. Quote
TreySr Posted June 10, 2015 Author Report Posted June 10, 2015 Thanks Nas. If you could please send a picture of where that might be located. Quote
