A different approach to 1G front coil-overs.
George
  • 10 months later...
Well, it looks like this is a 1 year update.
This set up has preformed well last summer and over the winter (raised back to stock for ground clearance). There was some clicking / popping from the right front spring. I suspected I would have to replace the flat thrust bearing, but it just needed some cleaning and a re-application of anti-seize. Now, no more noise. It would probably be ideal to clean and re-apply anti-seize about every 6 months. I may check to see if there is a polyurethane isolator the could be installed on top of the thrust bearing that would help keep out the crud.
Link to comment
Share on other sites
