hello to all im getting ready to swap in a Lx9 3.5 from a 2006 pontiac g6 its going into a 2000 buick century i already got new metal intake gasket set n throttle adapter n waiting on external crank trigger n also to take care of the map sensor plug n two wire temp. sensor n cam sensor plug im using fuel injector wireing harness from 2005 impala 3.4 which takes care of all the connectors ok now my car use 3 wire temp. sensor but 3.5 use 2 wire n so does the impala harness it should work fine right? n im very excited cause i do believe tht im going be first to swap in Lx9 into buick century but let me kn please also i already got the Lx5 throttle body n im using the 3.5 upper still but im modify the fuel reg. bracket
Good luck, man! Be sure to take lots of pics and post up your progress!!!
