Mstg007 Posted April 5, 2015 Report Posted April 5, 2015 Today I noticed as I turned in the driveway that I felt and heard the drivers side wheel make a light clunk noise. Did something break or get loose? It is for a1994 cutlass supreme convertible. Thanks! Sent from my iPhone using Tapatalk Quote
Nas Escobar Posted April 6, 2015 Report Posted April 6, 2015 Clunks can be a variety of things. I'd start off by checking the wheel. Jack up the car and shake the wheel with your hands at the 12 and 6 positions and the 3 and 9 positions after 12/6. If its loose, at best its loose lug nuts, but usually if the wheel shakes up and down its the lower ball joint or the wheel bearing. Left and right is usually the tie rod. Also, check the sway bar end. Its attached to the lower control arm Sent from my SAMSUNG-SGH-T989 using Tapatalk Quote
Mstg007 Posted April 6, 2015 Author Report Posted April 6, 2015 Great I will check it out when I get some time. Quote
