pitzel Posted March 27, 2015 Report Posted March 27, 2015 Okay two questions here: 1) I bought an oil pan gasket (Fel-Pro) in which the included instructions say to use no additional sealers. However, the GM factory service manual says to apply sealer (ie: RTV) at certain spots. Which should prevail? 2) When I have the pan off, is there any harm in removing the lower bearing caps (ie: one at a time) to inspect the bearings for wear/scoring/etc.? Being sure, of course, to re-install and re-torque appropriately? As many here may know, I am doing a sort of 'experiment' with the engine in not changing oil for extreme distances/times and want to take some pictures to prove (or disprove, or prove that I'm an idiot) that very long oil changes (ie: 40k miles) can be done on these engines without chewing up the bearings or causing a sludge monster. Thanks. Quote
RobertISaar Posted March 27, 2015 Report Posted March 27, 2015 if i were to pull main bearings.... I highly doubt I would be sticking the original ones back in. same goes for rod bearings, if you wanted to go that route as well. they're too cheap to not just outright replace if you have the pan off and have the peace of mind that new bearings bring. but, if you wanted to.... I don't see why you couldn't. Quote
19Cutlass94 Posted March 27, 2015 Report Posted March 27, 2015 If there is nothing wrong with the bottom end, I would leave everything alone. if the oil pan gasket is leaking that's one thing to fix that. Quote
rich_e777 Posted March 28, 2015 Report Posted March 28, 2015 In your experimenting would using an upgraded oil pump work better for you? Looking in the AZ system there is an option for the 3.1 to get a pump that says it has a 20% increase in capacity. As much as my car enjoys oil changes I don't think I`ll deter away from my normal routine, plus while its draining I can check everything else. Quote
Schurkey Posted April 1, 2015 Report Posted April 1, 2015 If you're using the GM gasket, use the sealer in the GM-specified place. Using an aftermarket gasket? Use the aftermarket procedure. You can inspect all but the thrust main bearing without too much problem. You will want to re-torque to factory spec. Disturbing the thrust main will require you to re-align the bearing half just as if you were assembling the engine--by pushing the crank lengthwise so the transmission-side of the thrust bearing is aligned properly. Not difficult, but easily forgotten or done incorrectly. Quote
White93z34 Posted April 5, 2015 Report Posted April 5, 2015 I'd say if you want a health report of the engine send a oil sample to Blackstone for analysis Quote
