trippsdadah Posted March 15, 2015 Report Posted March 15, 2015 OK I have a 96 cutlass supreme I'm putting in a 3800 sc from a 97 ssei what will I have to do I have trans wiring harness and computer so is there anything I should know or what works best any help I would be grateful for Quote
carkhz316 Posted March 15, 2015 Report Posted March 15, 2015 Someone correct me if I'm wrong, but aside from the aformentioned, the donor from the Bonne will have different motor mounts than what the Cutless needs. You'll need 3800 W-body mount(s). I'm not sure what is all involved to switch. Also, I think the OFA is different on the H-body to the W-body 3800's. Quote
l67ss Posted March 15, 2015 Report Posted March 15, 2015 To run an h body l67 in a w body you need to swap out the following parts-mentioned lower mount, dipstick tube, ac compressor, ofa, add dogbone mounts, trans mount bracket. Need following parts to make it fit-97-99 z34 driver axle, 98-99 z34 tb cable, 98 z34 rad heater and ps hoses, can use h body trans lines, 98-99 z34harness, 98 gtp pcm, can reuse 3100eng/trans mounts Quote
trippsdadah Posted March 15, 2015 Author Report Posted March 15, 2015 So if I get the z34 harness and gtp PCM what other wireing and programming will need to be done Quote
l67ss Posted March 15, 2015 Report Posted March 15, 2015 So if I get the z34 harness and gtp PCM what other wireing and programming will need to be done After rewiring c100 and swapping map plug should be plug and play Quote
trippsdadah Posted March 15, 2015 Author Report Posted March 15, 2015 OK is there any aftermarket providers for this harness Quote
l67ss Posted March 16, 2015 Report Posted March 16, 2015 OK is there any aftermarket providers for this harness Me.. but expect a lil lag on shipping Quote
trippsdadah Posted March 16, 2015 Author Report Posted March 16, 2015 What's it cost and would you have anything else I need Quote
l67ss Posted March 16, 2015 Report Posted March 16, 2015 What's it cost and would you have anything else I need $65+Shipping on the harness. And yup i have or can get everything you need to swap one in Quote
trippsdadah Posted March 16, 2015 Author Report Posted March 16, 2015 So what would you charge for all of it Quote
rich_e777 Posted March 16, 2015 Report Posted March 16, 2015 Me.. but expect a lil lag on shipping Good 2 know:thumbsup: Quote
l67ss Posted March 16, 2015 Report Posted March 16, 2015 So what would you charge for all of it Ill have to check all that i have and get pricing on what i dont. Location? Quote
l67ss Posted March 16, 2015 Report Posted March 16, 2015 Sioux falls SD Shipping on a harness would b around $25. Ill get rest of pricing when i wake up Quote
l67ss Posted March 16, 2015 Report Posted March 16, 2015 You need the parts to make an h body motor fit a w body too right? Quote
trippsdadah Posted March 17, 2015 Author Report Posted March 17, 2015 Yes all I'm concerned with is price if some parts are easy and cheap I have a you pull it yard close that is very good priced and have tons of cars I also know they have the computer in yard but no z Monte Carlo or lumina at this point so let me know what is best Quote
l67ss Posted March 17, 2015 Report Posted March 17, 2015 Yes all I'm concerned with is price if some parts are easy and cheap I have a you pull it yard close that is very good priced and have tons of cars I also know they have the computer in yard but no z Monte Carlo or lumina at this point so let me know what is best If you have a yard nearby you can grab the non z34 specify stuff off any 3800 w body.....sc or not. Ill try to come up with a complete list with prices Quote
