Windshield wiper alignment help please!
My 90 lumina wipers are hitting each other when the wipers are on. I took the wiper arms off and it seem that when the wipers are in park the passenger side wiper goes down way to fare. If any of you guys know what could give me a few pointers on how to solve this problem I would really appreciate it! Thanks.
Wipers basically grip onto the splines of the mechanism. remove, reposition, and try again. might take a few tries.
this should solve your issue, unless your mechanism is damaged. I did have one mechanism that would not quite work properly no matter what I tried, so I switched it out for a spare and it corrected the issue. your mileage may vary. good luck.
Are the blades the correct length? Seems elementary, but would explain the problem if not the adjustment issue.
max blade length is 20 inches. some cars list 19 as the stock replacement size but gm upsized to 20 in later years on the same mechanism, so 20 works on all of them.
