DR Customs strut tower bar brackets on a 96 Lumina?
I sent them an email. Here's the response.
"Joe I'm sorry but the brackets and bar won't fit your car since the bolt spacing is different than the Grand Prix/Impala/Monte Carlo. Don"
But I've been told that a a strut tower bar for a grand prix will fit and if it'll fit a monte carlo then it should fit a lumina right?
The brackets from a rear strut tower brace meant for a 97+ gp will fill fitthe rear of ur lumina but the bar itself will be too wide
I've got the bars but was hoping to use the mounting brackets to avoid drilling.
The bar is whats too wide
I haven't but they don't just bolt on. You have to drill holes to run the mounting bolts up through.
Get a cutlass supreme convertable fstb...its pure bolt on. Im guessing the braces you have require drilling through the strut mount itself......thas no bueno.
I found a guy that has the strut tops for the front that the bar will mount to, just need somethin for the rear.
But won't a second gen grand prix strut tower bar fit a 1.5 gen?
1.5 is closer to the 88-97 Cutlass, the 88-96 Grand Prix, the 88-96 Regal and the 90-94 Lumina.
The 2000 Monte Carlo is different from the 95-99 one.
So Gen 2 stuff doesn't fit 1.5 or 1.0 stuff.
