GHOSTOWLGRID Posted January 25, 2015 Report Posted January 25, 2015 I saw some videos of a 90 grand prix turbo, they floor it, and the engine goes way past redline. Is this normal for the car? I just got one and it does this as well. Quote
Psych0matt Posted January 25, 2015 Report Posted January 25, 2015 If it's chipped it may have the rev limiter removed, allowing it to rev freely Quote
EMNCFI Posted January 25, 2015 Report Posted January 25, 2015 The speedo and tach in these tends to screw up and read high, my speedo reads 10 higher than the hud, and my tach reads about 1000 higher than reality too. It is a problem that seems to get worse each month, one of these days I need to get my cluster rebuilt Quote
jman093 Posted January 25, 2015 Report Posted January 25, 2015 The speedo and tach in these tends to screw up and read high, my speedo reads 10 higher than the hud, and my tach reads about 1000 higher than reality too. It is a problem that seems to get worse each month, one of these days I need to get my cluster rebuilt Yeah, they pretty much all need rebuilt on these cars. All mine have been screwed up. Rob Saar on this forum fixes them affordably. Quote
GHOSTOWLGRID Posted January 27, 2015 Author Report Posted January 27, 2015 Yeah, they pretty much all need rebuilt on these cars. All mine have been screwed up. Rob Saar on this forum fixes them affordably. Ok, that is good to hear. Had me worried for a bit. Quote
RobertISaar Posted January 27, 2015 Report Posted January 27, 2015 the 89-90 TGP and 90 GP clusters seem to be the worst offenders in that instead of subtle errors in calibration, they tend to go insanely wrong. the wife's 90GP cluster was somewhere in the range of showing 3X as high as it should have on the speedometer and tach. the 91-93 GP clusters either don't fail as badly or it just happens less often, I get far fewer questions/requests about them. the 88-89 half-digitals... I don't know, it's kind of rare to even see one at this point. other w-body clusters have various issues as well.... I've noticed the 95-99 monte carlo/95-01 lumina clusters more often than not have accurate speedometers but their tachs read a bit high. EDIT: assuming you're running a stock calibration, where does your tach say the engine is idling at when fully warmed up? you can get a good idea of how far off it is knowing that and where the idle speed is being commanded. Quote
GHOSTOWLGRID Posted January 28, 2015 Author Report Posted January 28, 2015 the 89-90 TGP and 90 GP clusters seem to be the worst offenders in that instead of subtle errors in calibration, they tend to go insanely wrong. the wife's 90GP cluster was somewhere in the range of showing 3X as high as it should have on the speedometer and tach. the 91-93 GP clusters either don't fail as badly or it just happens less often, I get far fewer questions/requests about them. the 88-89 half-digitals... I don't know, it's kind of rare to even see one at this point. other w-body clusters have various issues as well.... I've noticed the 95-99 monte carlo/95-01 lumina clusters more often than not have accurate speedometers but their tachs read a bit high. EDIT: assuming you're running a stock calibration, where does your tach say the engine is idling at when fully warmed up? you can get a good idea of how far off it is knowing that and where the idle speed is being commanded. When it did idle correctly, it was about 3K rpm on the gauge but it was more like 1K ish. I have to plug in the scanner to read out the real numbers. It revved up because it has a high idle issue, it was about 2K-3K ish but the gauge was over 7K, so its definatly messed up. Tue turbo gauge, speedometer, and everything else is messed up as well, none of it seems to be reading correctly. Quote
RobertISaar Posted January 28, 2015 Report Posted January 28, 2015 sounds like the typical TGP cluster to me. Quote
