RedFlame Posted January 22, 2015 Report Posted January 22, 2015 I have a 2005 Grand Prix with a N/A 3.8L and the fans aren't turning on? What could be the issue? How can I fix this? Quote
Nas Escobar Posted January 23, 2015 Report Posted January 23, 2015 Fans are electric and controlled by the PCM. They are commanded to turn on when the temp. sensor reads -36F (don't ask why, just how it is) or 215-225F. If you're concerned about their function, turn on your A/C. They are programmed to turn on when you turn on the A/C as well. Quote
rich_e777 Posted January 23, 2015 Report Posted January 23, 2015 Is the engine getting hot enough to kick the fans on? It might be to cold outside or maybe a thermostat issue. Quote
Schurkey Posted January 23, 2015 Report Posted January 23, 2015 They are commanded to turn on when the temp. sensor reads -36F (don't ask why, just how it is) A failed coolant temp sensor or harness will show approximately -40F. A reading of -40 can mean it's really cold out, or it can mean that the sensor failed. Since it wouldn't take long for a running engine to raise it's temperature above -36, the ECM assumes that a -40-ish reading indicates a failed sensor--and turns on the fan as a safety precaution. Quote
