94 olds vert Posted September 19, 2023 Report Posted September 19, 2023 6 hours ago, litg5150 said: I've changed the battery changed the alt changed the ignition switch and ignition control module..still nothing I would check your ground wire from the battery to the frame. I bet it is corroded. Remove some of the black insulation from the copper if it has green on it, it needs to be changed out. If the ground area where that wire is bolted to the frame is rusty that will need to cleaned. Quote
GTPsurvivor Posted September 22, 2024 Report Posted September 22, 2024 On 2/3/2015 at 1:54 PM, AL said: Heres the problem causer, we are leaving it unplugged till I get a new one http://i1239.photobucket.com/albums/ff510/bigalwalker/20150203_112313.jpg Looks like that connector is conveniently in the rear side so that the seat must be removed . Were there any dash lights that were on that went off in relationship to this? Quote
