92cutlasssupreme3.1 Posted January 5, 2015 Report Posted January 5, 2015 (edited) Hello W body family. 92 Oldsmobile Cutlass Supreme, 3.1L. 161,123 miles >The column shift only sometimes activates my backup lights. I found that tapping, wiggling or holding the column shift lever activates them... Do you know what I need to do to fix this? Switch in column? or on trans? Thanks. Joe. Edited January 5, 2015 by 92cutlasssupreme3.1 Quote
55trucker Posted January 5, 2015 Report Posted January 5, 2015 The reverse lights are controlled by the transaxle switch which is located on the top of the trans assembly. In as much as where the problem actually is, start there, check the contacts for a worn/open situation. Quote
