Hey guys. Seeking some help. Got a 92 cutlass supreme with the 3.1. So im guessing its the first gen 3.1.
Today i start it. Starts fine. Runs for about 30 seconds then shuts off as if i turned the key off. No sputter. No hesitation. I think hm thats odd. Go to start it and now all it does it crank and crank. No fire.
Fuel pump is 3 years old. I can hear the fuel pump running so im thinking it cant be that. Also the fact of how it died. Seems to me like an ignition problem.
Now how do i know if its an ignition module or one of those crank and/or cam sensors?
Thanks guys.
Doesn't sound like a cam sensor at all...that wouldn't kill the engine, it would just batch fire the injectors. Of course, I'm thinking 3800 here...since it's a 92, I think the paperclip trick will work to run codes. I've never had an ignition module problem could reproduce exactly each time. I'm going with crank sensor...
I dont know how to test that. I would like to know what to do because i do not want to pay for a tow. Would you know how to test that?
Just wanted to update and say it ended up being the ignition module. Thanks for all the help! Very informative websites.
Good to know...and a hell of a lot easier to fix than most of the other possibilities. Glad you're back on the road.
