Mstg007 Posted December 5, 2014 Report Posted December 5, 2014 I just started my cat this evening and there was shot of white smoke coming out of the exhaust. I backed it up for a few and let it ran awhile. still had white smoke. I did see a little antifreeze under the engine. Car sounds fine. Any ideas besides the obvious head gasket failed or leak. We did drive last week for awhile and the car was fine. Thanks again for any feedback. Quote
RobertISaar Posted December 6, 2014 Report Posted December 6, 2014 how is your coolant level, in both the reservoir and the radiator? does the coolant look different than normal? does the oil look different than normal? Quote
Nas Escobar Posted December 6, 2014 Report Posted December 6, 2014 The cold would make the exhaust emissions look ""whiteish". However, I recommend that you check your fluids. Oil should be golden-brownish (or black if its not changed) and coolant should be bright to dull green (or red if you use dexcool). Quote
