1994 3.4l - slight little Oil and Coolant leak
I have had my convertible sitting in the garage for the past few weeks. I noticed a few drops of oil and alittle coolant to the side of the oil. Dumb question is there a sealant I can add to the engine to keep it from leaking?
New gaskets dude, there are no short cuts.:thumbsup: You`ll have to find out where its coming from and go from there. Many places oil and coolant can seep out of a 3.4.
Let's start a list of the "usual suspects"
OIL LEAKS
1. Oil pump drive O-ring
2. Oil pump drive O-ring
3. Oil pump drive O-ring
4. Oil pressure sending unit.
5. ???
COOLANT LEAK
1. Intake gaskets
2. Upper-to-lower intake manifold O-ring
3. Heater hose quick-coupler near thermostat
4. ???
OIL LEAKS
5. ???
COOLANT LEAK
1. Intake gaskets
4. Under throttle body hose
5. ???
#4 Happened to me. That tiny hose that has the clamps and is a bitch to get off leaked on me once. It took me a while to figure out.
This one is directed to the OP, but if you have a leak, trace it! Don't just look at the puddle, look at the pathline. Leaks usually leave a pathline from where they came from. My lower intake manifold leak did this. I traced it back to the rear bank lower intake manifold.
OIL LEAKS
5. ???
COOLANT LEAK
1. Intake gaskets
5. Water pump
6. ???
i replaced my water pump last month due to a leak.
