94-97 wiring harness differences
So quick question. I have a 97 3.4 Dohc with a getrag in my 87 Fiero. I found a guy who is selling a wiring harness from a 95 3.4 Dohc with a getrag out of his Fiero.
My question is what differences connector wise and sensors are there between the two harnesses. He did add a map sensor to his harness already. Thanks
As far as I recall, the wiring harness changed in 96 to accommodate OBD2. If you're running OBD2, then be wary otherwise I think the major difference is that the coils were mounted on the plenum in 96 whereas they are under the car in 91-95.
