Random/Multiple Cylinder Misfire
So I couldn't pass my smog, 97 Cutlass Supreme SL. I pulled two OBD codes 1-P0300=Misfires and 2-P0441=Evaporative Emission Control System Incorrect Purge Flow. I don't know why its misfiring and the Purge solenoid looks to be missing a hose. I replaced plugs and wires a lil while back. Any suggestions would a fuel cleaner help, might a vacuum leak be the cause or an old coil pack?
Edited by TheLazyRocket
Random misfires is usually fueling related. Last time you changed the filter?
Plugs/wires/etc are usually a specific P030# code.
I also replace my fuel filter about same time plugs and wire. the coil pack is probably old haven't messed with it.
I have had something similar happen. I kept having cylinder 3 and 6 act up, and ended up replacing the injectors, coil pack, and did a plenum cleaning.
