Chewy Peltier Posted September 12, 2014 Report Posted September 12, 2014 I need help instrument cluster somewhat works the Speedometer doesn't work tac doesn't work the turbo gauge doesn't work. Also the HUD is just all lit up. Need help on how to fix. Quote
Heartbeat1991 Posted September 12, 2014 Report Posted September 12, 2014 Did you look at the replies on the TGP forums? Your answer was provided there. Quote
Chewy Peltier Posted September 13, 2014 Author Report Posted September 13, 2014 Yes i have and cant find pictures or videos or anything to help fix it looked for over an hour searching for it. Quote
Heartbeat1991 Posted September 13, 2014 Report Posted September 13, 2014 It's not that simple. You'll need to send it out to be fixed, unless you have the equipment to do it yourself. Quote
Chewy Peltier Posted September 13, 2014 Author Report Posted September 13, 2014 Something about a Pencil tip soldering iron, Resistors i have all those things just Need instructions on how to do it Quote
RobertISaar Posted September 13, 2014 Report Posted September 13, 2014 it's FAR more complicated than that. you need to be able to feed the cluster test signals to calibrate needle position, without it, you're guessing at what the speedo and tach will end up at. Quote
