RichardLandis Posted September 12, 2014 Report Posted September 12, 2014 My sister has a 1994 Olds Cutlass 3.1. The transmission will not go into reverse or shift out of first gear. Checked the trans fluid. Level is fine at op temp. Color is brown. Quote
rich_e777 Posted September 12, 2014 Report Posted September 12, 2014 So it will go into drive but only in 1st? Or does shifting have any effect at all? You can try a fluid and filter change and add a bottle of Trans-X found at many auto part stores. Mine had a delay engagement and I added a bottle of it and it shifts just fine for now. If that doesn't work you will need a transmission rebuild or drop another one in. Quote
19Cutlass94 Posted September 13, 2014 Report Posted September 13, 2014 Brown transmission fluid is your first indication something is wrong. Sent from my iPhone Quote
RobertISaar Posted September 13, 2014 Report Posted September 13, 2014 if not burnt, it is at least old. Quote
RichardLandis Posted September 15, 2014 Author Report Posted September 15, 2014 It will go into drive but will not shift out of first gear no matter the speed. I am going to try a fluid and filter change on wednesday. Quote
Mstg007 Posted September 18, 2014 Report Posted September 18, 2014 Weird, how often are you suppose to change your tranny fluid? (Flush the system)? Quote
chevelle3504speed Posted September 24, 2014 Report Posted September 24, 2014 I'm guessing a broken reverse reaction shell. 4T60Es have trouble with this, and when it breaks, it creates exactly the situation you're describing. You have to completely disassemble the transmission to fix it, so you end up with an overhaul. Quote
19Cutlass94 Posted September 24, 2014 Report Posted September 24, 2014 Weird, how often are you suppose to change your tranny fluid? (Flush the system)? When mine was auto, I changed it every 30,000miles. These 4T60-E transmissions don't hold up very well to long intervals. Atleast that's what I've found. Sent from my iPhone Quote
l67ss Posted September 24, 2014 Report Posted September 24, 2014 When mine was auto, I changed it every 30,000miles. These 4T60-E transmissions don't hold up . Atleast that's what I've found. Sent from my iPhone there....fixed it Quote
