Turn signal speed
Is the speed on the turn signal usually slow.... Compared to my other newer cars... Or does it need to be replaced?
I'm assuming you're talking about 88-96 W-body? What do you have?
If that's the case, yes, it is normal for it to be that slow.
There is a mod to make it flash like newer cars though
Its that slow, its the flasher. You can upgrade it to a EL12 for a more rapid blink.
Sent from my HTC Sensation using Tapatalk
Verify that the turn signal wiring has proper voltage. Low voltage will slow the blinking.
