95 vert not sure if this is the grounding wire for the key fob? I thought that was buy the antenna but I dont have one there. Any thoughts? My trunk release does not.work nor key fob but I need to look into it more..there was an aftermarket unit installed so that may b
e messing up the factory.
Sent from my SCH-I545 using Tapatalk
Look closely at the release solenoid, Alldata shows a black/white wire to trigger it. That wire appears to have been extracted from a plug, just a pin on the end.
It looks like the wire for the remote trunk popper. But I don't see an actuator on the trunk.
Pin H on C1 of the RKE module is the black/white programming pin, if you can't find the plug you can use a hunk of wire to jump it to ground. The module is mounted to the "Rear Torque Box" in Alldata, whatever the hell that is.
Thanks ill look in the am..it had a selnoid I think with a switch on it for thrle remote lock on off..the seiniod has a plug and wire going into it..hmm
So I have a solenoid and the wire is hooked up...I followed the wire and in goes down to the right side of the trunk..thinking it's the grounding wire for key fob.
Is your trunk light on? The key fob programming wire usually is near the antenna.
Lock out switch for the remote trunk release. So people can't pop your trunk when you leave your car parked with the top down.
Sent from my Z30 using Tapatalk
Hm. I've never seen that before. Cool.
Is that wire for the trunk light?
Hey! That wire is Gray! It looked Black/White on my work computer in the first picture. That shouldn't be either of the things I mentioned earlier. I'm guessing somebody removed a trunk light or something along those lines.
Trunk light is still there and works..still stumped on this one
