Gasket for Fuel Tank
Just an FYI post. I recently had to replace the gas tank on my 1996 Gran Sport. The chick that had the car before ran something over and put a hole in it. It was patched but still weeped from the patch. I installed a new Spectra gas tank and the fit is okay. It does need a few tweeks with a hammer here and there to get it to fit properly. The tank comes with a new gasket. Throw it away and buy the AC Delco gasket. I installed the Spectra gasket and found that it would leak when the tank was full. When I pulled it, I compaired it to the AC Delco one. The Delco gasket is slight larger in diameter and of a harder rubber. The Spectra gasket is too flexable and will distort when installing the sender, causing it to leak. The Delco part number is 10152293 and costs $6 and change at Rockauto.
