Antmann1992 Posted August 17, 2014 Report Posted August 17, 2014 I had my windows down today and when i got home while i was putting the windows up my driver side got stuck halfway, i tried pulling it and it didnt budge also the switch made a white light a couple times instead of the orange light it makes. any suggestions Quote
Antmann1992 Posted August 17, 2014 Author Report Posted August 17, 2014 Just went for a ride and it loosened it, motors going it makes a nice grinding noise now. how hard is it to change it? Quote
jman093 Posted August 18, 2014 Report Posted August 18, 2014 IIRC, you have to remove the regulator. If so, it is riveted to the door frame and I'm also pretty sure the motor is riveted to the regulator, although the replacement one may bolt on. Outside of having to drill or cut a bunch of rivets, it is not especially difficult. While apart lube the shit out of the regulator and glass where the rollers ride and lube the guides as well. I'd recommend a ACDelco motor. They just work better and seem to have less propensity for grinding/slipping than aftermarket ones. My TGP had a new aftermarket motor in the left door when I bought it, but it would grind and jam. Put a Delco in it and it's fine. Quote
Antmann1992 Posted August 19, 2014 Author Report Posted August 19, 2014 Thanks for the insight ill check it out this weekend Quote
