67 GTO Posted August 15, 2014 Report Posted August 15, 2014 I have a 95 Grand Prix GTP. the engine has developed a miss. It seemed to come after a recent gas fillup. I cleaned the MAF, no luck. Now I am going to start to check parts and replace if needed. The first thing I am going to do is a tune up. I know it is a pain on these engines. I have to remove the plenum. Any tips to make the job easier. Or what to look for when doing it. Quote
Psych0matt Posted August 15, 2014 Report Posted August 15, 2014 I did a write up for the rear plugs a while ago, makes doing them a piece of cake in like 10 minutes. You don't have to remove the plenum, although that does free up some room. That's really otherwise the only painful part. http://www.w-body.com/showthread.php/49622-DOHC-rear-plugs-easy-solution Quote
67 GTO Posted August 15, 2014 Author Report Posted August 15, 2014 I did a write up for the rear plugs a while ago, makes doing them a piece of cake in like 10 minutes. You don't have to remove the plenum, although that does free up some room. That's really otherwise the only painful part. http://www.w-body.com/showthread.php/49622-DOHC-rear-plugs-easy-solution Thanks for the heads up. Quote
94 olds vert Posted August 15, 2014 Report Posted August 15, 2014 I find rear plugs on a 3.4 easy to do. Quote
Galaxie500XL Posted August 17, 2014 Report Posted August 17, 2014 Same here. There are small reliefs cut into the flange the rubber seal at the firewall on my car to accommodate an extension. The hardest part is getting the plug wires out, otherwise, it's pretty easy, once the strut brace is removed, and the rubber seal. Quote
94 olds vert Posted August 17, 2014 Report Posted August 17, 2014 Did your car have those slots/cuts from the factory? I notched out three little section for the extensi9n. Makes the rear plugs real easy. Especially if I have have to do them again. Quote
Galaxie500XL Posted August 17, 2014 Report Posted August 17, 2014 No, they're definitely not factory, they were done pretty sloppy, but they do work. Did your car have those slots/cuts from the factory? I notched out three little section for the extensi9n. Makes the rear plugs real easy. Especially if I have have to do them again. Quote
94 olds vert Posted August 17, 2014 Report Posted August 17, 2014 I tried to make mine look factory. I painted the raw metal after I cut it out. Quote
GOT2B GM Posted August 18, 2014 Report Posted August 18, 2014 Or you can unbolt the dogbone and pull the engine ahead with a ratchet strap. No cutting or notching required. Sent from my Z30 using Tapatalk Quote
mfewtrail Posted August 18, 2014 Report Posted August 18, 2014 Or you can unbolt the dogbone and pull the engine ahead with a ratchet strap. No cutting or notching required. Sent from my Z30 using Tapatalk Or a tilter tool made for doing that if you want to get all fancy with it. I have a homemade tilter I've been using for a few years. I believe the Lisle or whatever brand proper tool is relatively cheap though. Quote
Galaxie500XL Posted August 18, 2014 Report Posted August 18, 2014 IIRC, you can't do that with the LQ1...the motor mounts are different. Or you can unbolt the dogbone and pull the engine ahead with a ratchet strap. No cutting or notching required. Sent from my Z30 using Tapatalk Quote
94 olds vert Posted August 18, 2014 Report Posted August 18, 2014 I have done it. Park down hill remove the upper moumt the engine rolls forward a good amount. Quote
digitaloutsider Posted August 18, 2014 Report Posted August 18, 2014 You can do it. If both lower motor mounts are brand new it's a little bit of a struggle, but you can still do it. Quote
