Z34-5speed Posted August 7, 2014 Author Report Posted August 7, 2014 I'll do that. I'm trying to mentally prepare myself for pulling the interior. That's not my favorite thing to do. Kyle Quote
Heartbeat1991 Posted August 7, 2014 Report Posted August 7, 2014 Personally, I prefer the PMII. For 2 reasons : 1. I want to keep the car stock. 2. PMIII is far better performing than vacuum. Quote
GOT2B GM Posted August 8, 2014 Report Posted August 8, 2014 That's part of the excitement, will they work, won't they.... Russian roulette style Sent from my Z30 using Tapatalk Quote
Cully77 Posted August 8, 2014 Report Posted August 8, 2014 Congrats on the purchase, I like your collection-- and welcome back! Quote
Z34-5speed Posted August 12, 2014 Author Report Posted August 12, 2014 Some updates: Sent the cluster off for repair and received these in the mail!: Quote
GOT2B GM Posted August 12, 2014 Report Posted August 12, 2014 Bushings are on their way! Sent from my Z30 using Tapatalk Quote
Z34-5speed Posted August 20, 2014 Author Report Posted August 20, 2014 The repaired gauge cluster is on its way home now. I'm can't find a good write-up on how to switch out the Master Cylinder/Vac system from another w-body. Anyone have a link? Thanks! Kyle Quote
GnatGoSplat Posted August 20, 2014 Report Posted August 20, 2014 No write-up that I'm aware of, but see Sharup's pics in this thread: http://www.w-body.com/showthread.php/80221-PM-III-dead!/page2 Quote
Z34-5speed Posted August 29, 2014 Author Report Posted August 29, 2014 Just ordered a PMIII unit from Cardone. Got it through Summit for $1050.00 with the core charge. I'm fully expecting them to email me to tomorrow to notify me that the part isn't available, i just figured i'd give it a shot before I dive into converting it. I'll keep this updated! Kyle Quote
Heartbeat1991 Posted August 29, 2014 Report Posted August 29, 2014 You didn't have one that came with the car? I thought I saw in one of your threads that there was one with it. Quote
Z34-5speed Posted August 30, 2014 Author Report Posted August 30, 2014 Yes, I do have the one that came with it, however I don't want to go through the trouble of reinstalling it only to find out the entire unit is bad. I'll keep it and play with it later. Kyle Quote
Heartbeat1991 Posted August 30, 2014 Report Posted August 30, 2014 You can plug it in without hooking it all up. Just remove the washer bottle, prop the unit up on the battery, and plug it in. As long as you don't push the rod in, it shouldn't leak anything. I would have done that before spending so much on a new one. My guess is they will require your core to rebuild it. How's progress otherwise? Quote
Z34-5speed Posted August 31, 2014 Author Report Posted August 31, 2014 The car is a little over the hour from here, so i haven't been able to play with it in a few weeks. I've been gathering parts so that I can spend a whole weekend on it. Kyle Quote
Z34-5speed Posted September 9, 2014 Author Report Posted September 9, 2014 Far as I know, Summit still hasn't shipped the PMIII, however they haven't called to say it isn't available either. I went down and re-installed the rebuild cluster and the dogbones. Making progress! Kyle Quote
Z34-5speed Posted September 15, 2014 Author Report Posted September 15, 2014 Welp: Didn't hear anything from Summit about the PMIII unit, so i called and just cancelled the order. They claimed it was on backorder till the end of the month, after emailing me that it would be shipped the 13th. Going to make a PullAPart trip Saturday and try to acquire the parts from another w-body for the conversion. What year booster/master would be an upgrade over a typical 90 w-body? Thanks! Kyle Quote
Garrett Powered Posted September 21, 2014 Report Posted September 21, 2014 What about the Rockauto one? Quote
GnatGoSplat Posted September 22, 2014 Report Posted September 22, 2014 Z34-5speed said: What year booster/master would be an upgrade over a typical 90 w-body? I think the master cylinders were the same for first-gens 88-96. I thought it was possible to remove the master from an ABS VI assembly and you'd be left with a regular master cylinder. Not sure, someone like Ken might now for sure. Boosters were upgraded in 94 to a larger unit, but if you have any future dreams of changing to a 5-speed manual, stick to the smaller 88-93 style booster. Quote
Heartbeat1991 Posted September 23, 2014 Report Posted September 23, 2014 GnatGoSplat said: I think the master cylinders were the same for first-gens 88-96. I thought it was possible to remove the master from an ABS VI assembly and you'd be left with a regular master cylinder. Not sure, someone like Ken might now for sure.Boosters were upgraded in 94 to a larger unit, but if you have any future dreams of changing to a 5-speed manual, stick to the smaller 88-93 style booster. Yes, ABS VI should be able to be removed leaving a non-abs master, but it's easier to just buy a new master. They are only about $35. Keep in mind that you'll have to pull the dash and swap out the mounting plate. Quote
RobertISaar Posted September 23, 2014 Report Posted September 23, 2014 the way that the ABS-VI hardware sandwiches onto the master cylinder... i'm not sure. i've looked at it on the MC since the ABS hasn't been useful for at least a decade and i keep seeing something that tells me something about it won't work. Quote
GnatGoSplat Posted September 23, 2014 Report Posted September 23, 2014 (edited) Yeah, what I'd be concerned about an ABS master cylinder is if the outlets are threaded like a regular one. The MC and Modulator are connected via "transfer tubes", but I've never actually seen one. Maybe they're threaded on the MC end and press-fit into the modulator, but I wasn't sure if maybe they're press-fit on both ends and the MC outlets are smooth instead of threaded. Well, if they're only $35 new, probably not be worth the trouble of getting a used one. I'm sure a JY would want $35+ for a used one with ABS modulator attached anyway, and non-ABS cars might be harder to find since due to age. Might be worthwhile to do what Sharup did and make an adapter instead of pulling the dash. EDIT: Looked them up on O'Reillys website, different p/n for ABS vs non-ABS, but looks identical. Outlet ports kind of look smooth on the ABS version on one angle, but another angle clearly shows threads so I'm still not sure. Edited September 23, 2014 by GnatGoSplat Quote
Heartbeat1991 Posted September 23, 2014 Report Posted September 23, 2014 I've never tried to split one apart. I have several ABS units here. I don't have a use for them. Maybe i'll see what's involved and what it looks like in there. There are quite PMIIIs out there. Easiest route would be to fix the one he has or replace it with another. But reliability wise, maybe do a swap. I don't drive mine very often. So I prefer to keep it all original. Quote
intern8tion9l Posted September 24, 2014 Report Posted September 24, 2014 That adapter that sharup made looks great, hopefully he or someone he shared the files with posts how to make it Quote
Z34-5speed Posted September 25, 2014 Author Report Posted September 25, 2014 I'd prefer to avoid pulling the dash for obvious reasons, so i'll look into his adapter. I'm kinda afraid to dive into it because i'm not sure exactly what all was changed when they put the Geo Metro booster/Master on the car. I do know the ends were reflared to match the Metro piece. Quote
Z34-5speed Posted September 25, 2014 Author Report Posted September 25, 2014 *Copy/Paste from the adapter plate thread* I'm looking through the pics of his adapter plate and rod extension and am a bit confused. I'm pretty clueless with Master Cylinders. What is going on in the pics where he shows the disassembled rod? Also, can someone better explain how and what he used for that adapter plate? Thanks! Quote
