Will the 2.3l dohc ld2 from a 90-91 grand prix bolt up to a 4t60 if not what 5 speed did they use in then 90-91 grand prix was it a getrag?
I believe the LD2 used the 3T40 (or THM125) with the 3.18 FDR.
The LG0 (HO) had the 5 speed and it was a 282 but with 3.61 FDR.
Edited by ManicMechanic
but would it work with the 4t60 because thats what my 90 lumina has now with the 3.1l but im looking at a z24 that has the 2.3l in it and i would rather have 4 speed over 3 speed
No. Bellhousing bolt pattern is different.
If you want a Quad 4 5 speed, then you gotta get the Q4 and the 282 MUNCIE.
And yes, the Muncie was made by Getrag but there were 2 Getrags, the Muncie from the early 90's and the NVG T550 which I think started production in 93... By this time there were no 5 speeds in W bodies... or so I want to say, I know 94s were all automatics and had OBD1 with OBD2 codes (the infamous OBD1.5).
If you want an auto Q4, then you have to basically get a J body powertrain in there, which your issue would be mounts and the fact that you would need custom transaxles and a PCM tune as the PCM will not like that at all, despite being OBD1. Q4's were mated to a Getrag or a TH125. If you wanted a 4 speed, the closest thing you would get to is a 4T40 from a Twin Cam engine. Come to think of it, if the Twin Cam has the same bellhouse pattern as the Q4, you could get an F23 from a later model Cavalier or Grand Am/Alero.
Regardless it would be quite the chore.
so not worth putting in the 2.3l dohc into my lumina? or would it just be easier to do a l67
from 94-98ish, you could get a quad4(or 2.4) with a 4T60E.
dont want 4t60e i like as little electronics as possible stuff is easier to fix without it and you dont have to worry about a stupid electronic switch going bad to ruin a trip etc.
I personally would just look for a 5 speed Q4 Cutlass Supreme.
they seem to exist everywhere for a surprisingly low price where i do not live.
Welcome to my world... Where parts for a CSC are found at least 5 states to the west.
