A bolt fell out of my driver side rear caliper and I was just wondering if anyone knew the exact size. Its one of the two bolts that mounts the brake to the hub.
I`m not sure of the size but if its one of the caliper bolts I believe you can get new ones from Autozone. It just fell out? I would be thinking about getting a new caliper because it seems the threads in your current one are bad. Or are you referring to the two larger bolts that hold the outer sway bar bracket(if equipped) to the knuckle? If one of those fell out you might need a few other parts replaced.
Hit up a junkyard? Shouldn't take 5 minutes to find one and grab a bolt for $.50?
The calipers are brand new, they just didn't come with some of the hardware so i had to reuse a few things.
