Drummer Posted July 8, 2014 Report Posted July 8, 2014 (edited) My quick disconnect connector for the cooler line that go into the transmission is leaking. Is there an o-ring inside that I can replace or do i have to replace the whole connector? Where can I get one at? Edited July 8, 2014 by Drummer Quote
Cutlass350 Posted July 9, 2014 Report Posted July 9, 2014 You likely need a new fitting: http://www.amazon.com/ACDelco-24236554-Transmission-Fitting-Assembly/dp/B0049OKZDA http://www.rockauto.com/dbphp/x,catalog,337,partnum,24236554,d,ACDELCO_24236554.html How to replace the fitting: Nice tool to make it easy to remove the hard line from the quick connect line, without having to remove the PITA clip: http://www.amazon.com/OTC-7937-Transmission-Cooler-Disconnect/dp/B000OCIWR2/ref=cm_cr_pr_product_top If the end of the hard line is bad: http://www.amazon.com/Hayden-Automotive-397-Transmission-Fitting/dp/B000EPRCAC Good Luck! Quote
Leadfoot Posted July 9, 2014 Report Posted July 9, 2014 I just replaced the o-ring on mine and it fixed the problem. That is not always the case, but is a cheap simple start to the solution Quote
