Have a 2000 GLS intrigue with the 3.5 platform. I have been plagued with intermittent problems. The car has 70,000 miles. The following problem is at times it will miss at an idle and want to shut off, and while driving down the interstate it will loose all engine power, and I can play with the accelerator to recover. At first I thought it was the fuel pump as it had low fuel pressure, the problem continued (changed fuel pump), I thought it might be bad gas, not so. I have changed the MAP sensor, I have tried the following: a new MAF sensor, change the cam sensor, I tried a new IAC valve, checked the coil packs, checked the plugs, check the TPS with no resolve. There are no codes stored. Any sugestions? Thoughts?
