CW09 Posted June 23, 2014 Report Posted June 23, 2014 How do I take the carrier with the spider gears off of the axle? I have the differential cover removed and everything. Carrier and spider gears are out in plain sight. Quote
LumiLTZ Posted June 24, 2014 Report Posted June 24, 2014 How do I take the carrier with the spider gears off of the axle? I have the differential cover removed and everything. Carrier and spider gears are out in plain sight. You're talking about removing the final drive from the output shaft? Did this just yesterday. I drove a wedge in between the cross shaft and the end of the output shaft, and that popped the final drive off. Illustration of the process I went through if this gives any help: Quote
