Help for tuning my Z34 for 5 speed
Just got HP Tuners and I haven't really dug into it much, but I'm wondering if anyone has any pointers or walkthrough for what I have to do for PCM changes for the 5 speed swap. Yes, I searched all over HPT.com and internet and haven't found anything yet. Any help would be appreciated. Thanks!
I have helped people in the past, but it was with DHP. If you had a bin and tinytuner I believe there is a choice to disable the trans. But if you are just leaving the trans range switch in neutral, the. You will need to change the rev limiter. Deff max and min out the shift points so it never shifts, and remove trans torque management. What base file are you starting with?
It's a 5 speed MANUAL. I don't have to worry about shift timing and TM. I just need to disable codes I guess and figure out how to enable cruise control. The other thing that is kind of strange is I've jumpered the range select wires together to show either N or Drive range (I cut the switch off so I could do the other wiring like starter, reverse and trunk) and there has never been a rev limiter. Oh well.
