So my key fobs have never worked for opening the trunk, and neither has the yellow dash button (have a replacement one as the original worked for a while but sporadically). Anyway, I was going through my owner's manual and found the convertible insert and it shows a toggle switch located behind one of the trunk panels and it is used to disable the key fob for accessing the trunk as a security measure. Problem is, I can't find it anywhere,
Can someone please describe to me exactly where it's located?
Thanks,
Greg
It's on the trunk lid itself just to the left of the trunk latch. I put a rubber switch cover on mine. You should be able to see the brass nut at the base of the cover on mine.y9ejy9e9.jpg
Sent from my iPhone using Tapatalk
I was under the impression that only the convertibles got that switch...
Um, sorry about that...the switch on my '95 is in the same location, but has a small paper tag glued to the bracket, showing which direction is on or off. I like the idea of covering the switch--looks neater that way.
They did.
Great! Thanks for showing me that. But, it didn't work.:( When I use my fob, I could hear a clicking coming from further towards the back of the back seats. I pulled the carpet back and found a small box wrapped in blue plastic with a harness plugged into it. Every time I hit the button, you could hear a faint click (sounded like something was trying to unlock but couldn't).
This box is mounted behind the left rear seat on top of the metal shelf that the pump and hoses are below on the other side.
Any ideas?
Greg
Edited by ILoveSun
I think your RKE box may be going bad. If you ground out the wire by the antenna do the locks cycle? They should all lock and unlock.
If you do that you need to do the little song and dance in the FAQ section to re-link the remotes.
ummmm, if the yellow button on the interior of the car is not working either, then it most likely is not the keyless entry module that is the problem.
The box clicking is a sign that it IS working, but somewhere there is an interrupt.
I would recommend doing an continuity test of the wiring from the trunk release to the button to see if the wire is not cut or damaged somewhere first.
Also, I have seen those trunk release solenoids go bad. You could just have a bad trunk release solenoid, or even just a bad ground (the solenoid is grounded directly to the car so that is unlikely).
I would recommend first of all trying to manually pop the trunk solenoid and make sure it is not seized up. There should be enough of a gap in there that you can stick your finger in and slide it over. If it does not move, then its seized and that is your problem.
Don't be so quick to blame the solders on the newer keyless modules. I've yet to see a newer one like used in the 1994+'s go bad.
I've seen the toggle switch bad on Verts. Unplug the toggle switch and connect the latch directly(bypassing the toggle).
  • 3 weeks later...
Swapped toggle, no luck. Gotta be the actuator, but can't find a source for one.
Any ideas?
Greg
Coupe and sedan are the same I believe.
Yeah, when I searched I just looked for "1994 Cutlass Supreme Trunk Actuator" and came up empty.
Are they hard to find, or is it just me??
Greg
Shouldn't be hard at all. I think they may be the same actuator used on others, like Corsica/Beretta.
