Michael Savage Posted May 27, 2014 Report Posted May 27, 2014 Just did a 2003 Topswap to my 1995 Monte Carlo LS 3100. To But now I've ran into something. During idle every few seconds the engine vibrates or jumps kinda hard. Any ideas what to check on that could have caused it? Quote
l67ss Posted May 28, 2014 Report Posted May 28, 2014 Just did a 2003 Topswap to my 1995 Monte Carlo LS 3100. To But now I've ran into something. During idle every few seconds the engine vibrates or jumps kinda hard. Any ideas what to check on that could have caused it? Id check both the map and iac Quote
Michael Savage Posted May 28, 2014 Author Report Posted May 28, 2014 I'll get on it tomorrow when it stops raining but as far as I could tell there's no vacuum leaks but I could be wrong thanks for that I'll check over the hoses again. Anything else is much appreciated Quote
Michael Savage Posted May 28, 2014 Author Report Posted May 28, 2014 Iac position at idle is 15 is that right or should it be at 0 haven't paid attention to it in the past. MAP(kPa) idle is 44 MAP(V) idle is 1.02 Is all of this correct or is something off? Quote
Garrett Powered Posted May 29, 2014 Report Posted May 29, 2014 my red tgp sits at idle with 36.83 MAP up to 48 in gear. thats .63 up to 1.0 volts in D. the IAC I have cranked 37 up to 40 in D at idle Quote
Michael Savage Posted May 29, 2014 Author Report Posted May 29, 2014 So sounds about rite then. But iAC seems low on mine should. Try swapping that? Quote
Michael Savage Posted May 29, 2014 Author Report Posted May 29, 2014 Swapped to a 2.8 IAC most of the hard jumping is gone still a little there. The 2.8s is way different so I'm hoping when I pick up a new one will fix it. Quote
Garrett Powered Posted May 29, 2014 Report Posted May 29, 2014 why buy new one? you will get the same result until you tune it different. Quote
Michael Savage Posted May 29, 2014 Author Report Posted May 29, 2014 3.1 has the long coil iac and the 2.8 has a short plastic nub style I've always noticed different drive ability differences in the 2. Seeing as how the 2.8 iac got rid of 80% of the jumping I'm thinking it's my iac. Whenever I've had to run the 2.8 in the past the idle usually had a little roughness so I'm guessing the 3100 iac I have went out Quote
Michael Savage Posted May 29, 2014 Author Report Posted May 29, 2014 And also since I have a 95 I have OBD 1.5 so I have no tune ability other than what it can do itself Quote
Michael Savage Posted May 29, 2014 Author Report Posted May 29, 2014 Oh it's not a 2.8 iac it's from a 2.2/2.4 Quote
Garrett Powered Posted May 30, 2014 Report Posted May 30, 2014 I could tune it for you, but do you have a way to flash your car with it? Quote
Michael Savage Posted May 30, 2014 Author Report Posted May 30, 2014 I have an extra computer I could send you I keep a spare in my truck for emergencies along with most parts lol. Figured out what's possibly causing the issue. The hose that connects to the silver canister on the front valve cover to behind the throttle body on the manifold to that canister with the red plug under the coil. If you pull the silver canister our of the valve cover while it's running the car doesn't run any differently. What part of it should I try replacing first? Quote
Michael Savage Posted May 30, 2014 Author Report Posted May 30, 2014 But flashing wise i can't do it myself and I have no experience flashing my OBD 1.5 system Quote
cutlassdude96 Posted May 30, 2014 Report Posted May 30, 2014 that little canister is you PVC valve Quote
Nas Escobar Posted May 30, 2014 Report Posted May 30, 2014 And also since I have a 95 I have OBD 1.5 so I have no tune ability other than what it can do itself FYI, it's OBD1, not 1.5. People affectionately call it 1.5 but it still uses OG OBD protocols. The only difference was that in 94, it lost the capability of the paper clip/metal jumper diagnostic method, where the SES light would blink a certain way and certain amounts to tell you the code it's throwing. If you really want to tune your PCM, talk to Robert Saar. He's very knowledgeable about electronics. Quote
Michael Savage Posted May 30, 2014 Author Report Posted May 30, 2014 Oh mine still has the SES jumper light it's A/B on my car. It came with a jumper key on a keychain in the glove box with the manual. So I do have OBD 1. Robert Saar has told me that it can't be tuned that I need to convert to OBD 2 if I want it to be tune able. Quote
Michael Savage Posted May 30, 2014 Author Report Posted May 30, 2014 So the metal one is the PVC Valve. What about this one? Quote
l67ss Posted May 30, 2014 Report Posted May 30, 2014 Evap So the metal one is the PVC Valve. What about this one? Quote
Michael Savage Posted May 30, 2014 Author Report Posted May 30, 2014 Thanks man haha it's something in this asymbally causing my missfire from what I can gather. If I take it off it makes no difference in how the car drives or idles. So it's gotta be a part of it. Quote
Michael Savage Posted May 30, 2014 Author Report Posted May 30, 2014 What's the part name or number to search? Evap doesn't show up on advance auto Quote
Garrett Powered Posted May 30, 2014 Report Posted May 30, 2014 [TABLE] [TR] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvlm] [/TD] [TD]Vapor Canister Purge Valve[/TD] [/TR] [/TABLE] [TABLE=class: partnode, width: 809] [TR] [TD=class: ygtvhtml][TABLE=class: main, width: 808] [TR] [TD=class: center, colspan: 5, align: center][TABLE=class: layout, width: 806] [TR] [TD=class: left closebtn, align: left] [/TD] [TD=class: center]Related Parts[/TD] [TD=class: right, align: right]Choose for Me to Minimize Cost [/TD] [/TR] [/TABLE] [/TD] [/TR] [TR] [TH=align: center]1995 CHEVROLET MONTE CARLO 3.1L V6 : Emission : Vapor Canister Purge Valve [/TH] [TH=align: center]Price[/TH] [/TR] [TR] [/TR] [TR=class: part0, bgcolor: #F0F0F0] [TD=class: alternate0][TABLE=class: parts, width: 716] [TR] [TD=class: left][TABLE=class: layout, width: 588] [TR] [TD=class: partlayout]DORMAN Part # 911072 {#1997201}[/TD] [/TR] [/TABLE] [/TD] [TD=class: right, align: right] [/TD] [/TR] [/TABLE] [/TD] [TD=class: center leftrightborder boldfont priceonly alternate0, align: center]$15.19[/TD] [/TR] [TR=class: part0, bgcolor: #F0F0F0] [TD=class: alternate0 center, align: center][/TD] [/TR] [TR=class: part1, bgcolor: #E0E0E0] [TD=class: alternate1][TABLE=class: parts, width: 716] [TR] [TD=class: left][TABLE=class: layout, width: 653] [TR] [TD=class: partlayout]STANDARD MOTOR PRODUCTS Part # CP208 {Click Info Link for Alternate/OEM Part Numbers} SOLENOID; Pin Terminals; Terminal Gender: Male; Number of Terminals: 2;Number of Ports: 2;Number of Hose Connectors: 2; Hose Size - Inches: 5/16"; Connector Gender: Female; Male; Male[/TD] [/TR] [/TABLE] [/TD] [TD=class: right, align: right] [/TD] [/TR] [/TABLE] [/TD] [TD=class: center leftrightborder boldfont priceonly alternate1, align: center]$21.79[/TD] [/TR] [TR=class: part1, bgcolor: #E0E0E0] [TD=class: alternate1 center, align: center][/TD] [/TR] [TR=class: part0, bgcolor: #F0F0F0] [TD=class: alternate0][TABLE=class: parts, width: 716] [TR] [TD=class: left][TABLE=class: layout, width: 612] [TR] [TD=class: partlayout]AIRTEX / WELLS Part # 2N1009 {#1997210, PV137} SOLENOID Purge Valve[/TD] [/TR] [/TABLE] [/TD] [TD=class: right, align: right] [/TD] [/TR] [/TABLE] [/TD] [TD=class: center leftrightborder boldfont priceonly alternate0, align: center]$22.79[/TD] [/TR] [TR=class: part0, bgcolor: #F0F0F0] [TD=class: alternate0 center, align: center][/TD] [/TR] [TR=class: part1, bgcolor: #E0E0E0] [TD=class: alternate1][TABLE=class: parts, width: 716] [TR] [TD=class: left][TABLE=class: layout, width: 616] [TR] [TD=class: partlayout]ACDELCO Part # 214565 {#01997201} VALVE,Evaporative Emission Canister PURGE SOL 2 PORT VAC-2 blade terminal[/TD] [/TR] [/TABLE] [/TD] [TD=class: right, align: right] [/TD] [/TR] [/TABLE] [/TD] [TD=class: center leftrightborder boldfont priceonly alternate1, align: center]$30.79[/TD] [/TR] [TR=class: part1, bgcolor: #E0E0E0] [TD=class: alternate1 center, align: center][/TD] [/TR] [/TABLE] [/TD] [/TR] [/TABLE] [TABLE] [TR] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvtp] [/TD] [TD]Engine[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvdepthcell] [/TD] [TD=class: ygtvtp] [/TD] [TD]Exhaust[/TD] [/TR] [/TABLE] Quote
Garrett Powered Posted May 30, 2014 Report Posted May 30, 2014 http://support.moates.net/gm-94-95-reflash-or-not/ ...dang Quote
Michael Savage Posted May 30, 2014 Author Report Posted May 30, 2014 Yeah mine uses the G2 Tunercat I believe. Quote
Michael Savage Posted May 30, 2014 Author Report Posted May 30, 2014 I'll be a son if a ..... I finally fixed it I guess my non resistant .080 gapped plugs were too big =.= riding so much better now if it acts up anymore I'll mess with that vacuum hose Quote
