Lumina Z34 Getrag 284 Clutch Kit - What is best?
Sunday my car had to be towed because it started "screeching" very loudly and I could smell smoke. The verdict is that I need to replace components in the clutch.
Center Force does not make a full clutch kit for my car.
Phoenix, Zoom Performance, RhinoPac, Exedy, Centric, Clutchnet, and Valeo do.
Spec offers Stage 1 to 4 also...but they are expensive.
What is the best clutch kit for the Getrag 284 in a 1992 Lumina Z34? I am not looking for a drag car...mine is a daily driver that I would like to perform and last.
Thanks,
Tom
I ran a brute power in my 91 GP SE for about 80,000 miles, and the thing still bites hard under hard shifting conditions. The box said brute power with the borg warner logo, but it was a Valeo disc and had Daikin throwout bearing. I think most of the stuff is the same and just put into different boxes, as there is no way there are seven different manufacturers making their own clutch kits, especially for such a narrow market as 284 W's. Even an ACDelco boxed kit I recently picked up had the same exact stuff as the brute power kit, including a Valeo disc.
I know a few people around here are running spec clutches, and I believe they make their own, but as said before I would be willing to bet the rest are just repackaged and are all the same. I need this information too because I want to get a new clutch in the next few years
I've been running the Spec stage 2 in my z34 for several years and put about 15,000 miles on it. I'm pretty happy with it. It grabs firmly but its not too much for my stock engine, no annoying chattering. Very nice daily drivable clutch. Granted they are around $700 these days though.
Just don't expect much if anything from Spec in the lines of customer service, its somewhere between non-existent and awful. They also tend to make a good bit of noise when you first start the car, it goes away after a couple miles driving though.
Spec stage 3+ in my 284 swapped Impala holds whatever power I can give it and the pedal isn't too stiff, although it is very chattery and either on or off. I would recommend something a little less extreme for a DD. +1 on spec's customer service being non existent, but they do make a good clutch.
Spec stage 2 is the way to go
I have a Spec Stage 2+ in my 282 swapped 92 GTP and would not recommend it..... its too grabby and chattery for a stock engine.
Just a regular Stage 2 is what it'll get next time
  • 3 months later...
I'm interested in this as well, and additionally in anyone's experiences with a company other than SPEC -- $600 for a clutch may break my bank if my clutch is too worn to be reused.
Edit: So, RockAuto presents several choices for this application:
[TABLE=class: main]
[TR=class: part0]
[TD=class: alternate0][TABLE=class: parts]
[TR]
[TD=class: left][TABLE=class: layout]
[TR]
[TD=class: partlayout]AUTOPART INTERNATIONAL Part # PRFMU700451
New Clutch Kit; DIAPHRAGM - 9 11/16 X 23T X 1 - PULL TYPE CLUTCH; GT Model [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: right][/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: center leftrightborder boldfont priceonly alternate0]$101.79[/TD]
[/TR]
[TR=class: part0]
[TD=class: alternate0 center][/TD]
[/TR]
[TR=class: part1]
[TD=class: alternate1][TABLE=class: parts]
[TR]
[TR]
[TD=class: partlayout]BECK/ARNLEY Part # 0616062
Clutch Kit 9-3/4" DIA - SPLINE DIA 1" - 23 SPLINES - 246MM DIA; GT Model [Wholesaler Closeout -- 30 Day Warranty][/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: right]BA%25200616062-1.jpg
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: center leftrightborder boldfont priceonly alternate1]$254.79[/TD]
[/TR]
[TR=class: part1]
[TD=class: alternate1 center][/TD]
[/TR]
[TR=class: part0]
[TR]
[TR]
[TD=class: partlayout]EXEDY Part # 04127
Pull Type,; Disc mm 246; Disc in 9-5/8; Splines Dia 1; Splines 23[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: right]04127.jpg
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: center leftrightborder boldfont priceonly alternate0]$297.79[/TD]
[/TR]
[TR=class: part0]
[/TR]
[TR=class: part1]
[TR]
[TR]
[TD=class: partlayout]AMS AUTOMOTIVE Part # 04127 9.688" X 1.000" X 23T
Flywheel Spec: FLAT (Only 4 Remaining)[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: right]04-127.jpg
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: center leftrightborder boldfont priceonly alternate1]$322.79[/TD]
[/TR]
[TR=class: part1]
[/TR]
[TR=class: part0]
[TR]
[TR]
[TD=class: partlayout]SACHS Part # K7004501
Standard; Pull Type; Outer Diam: 9 11/16; Inner Diam: 1; TEETH:23T[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: right]K70045-01.jpg
[/TD]
[/TR]
[TR]
[TD=colspan: 2]* Stocked in outlying warehouse--shipping delayed up to 1 business day[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: center leftrightborder boldfont priceonly alternate0]$460.79[/TD]
[/TR]
[TR=class: part0]
[/TR]
[TR=class: part1]
[TR]
[TR]
[TD=class: partlayout]VALEO Part # 52462202
Pull Type Unit; Disc Size:9 11/16 x 1 x 23 (Only 2 Remaining)[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: right]52462202.jpg
[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[/TD]
[TD=class: center leftrightborder boldfont priceonly alternate1]$476.79
[/TD]
[/TR]
[/TABLE]
I'm not sure I'd want the $100 special, but I'm considering the Exedy... if I can find out more info about it. I'm not going to be racing it, but I'm not interested in spending nearly an entire paycheck on one.
Edited by GP1138
Just an FYI for anyone, I talked to Spec technical support some time ago and they told me that Exedy makes their clutches for them. Not sure what they do after that, but that's what iI was told
Bully clutch. Only clutch I'll ever run. Fuck them spec clutches.
Sent from my iPhone
Where do you get these Bully clutches and will they handle a L67 and beyond?
I wouldnt hesitate to get that Exedy, but i think i went Sachs, which is the OEM brand for alot of german cars.
The reason is the Exedy is cheap is because it was a closeout. Gotta love the amount of closeout stuff one can get on rockauto.
I will likely be ordering it next week -- I get my last check from my previous job, it will be the last "spare" money I have until tax time next year. If I'm going to fix this car, it's going to be done right.
