lugorobert Posted May 8, 2014 Report Posted May 8, 2014 Hi guys, the car is a 98 riviera 3800 series 2 supercharged 276k, well i had the coupler rattle, pulled the nose off replaced the coupler and new oil. no more rattle!! i also checked for play (up or down, in or out on the nose) and its all very tight. i turned the supercharger by hand and listened and it sounded and felt smooth. maybe im paranoid but when i listen to the car idle i can hear noise from the supercharger, im not sure how to describe it, maybe like a chatter? its a very light sound, it sounds mechanical, i used zzperformance sc oil 6oz. the sound does not increase or get louder when revved. is this just the normal mechanical sound of the supercharger? again this is not a rattle more of a very very light chatter. thanks for any input. Quote
Imp558 Posted May 8, 2014 Report Posted May 8, 2014 Harbor freight sells mechanic stethoscopes super cheap, other guys put a screwdriver to their ear (I have longer hair so that close to moving parts is bad) anyway that can really help to pinpoint sounds. I thought I had lifter tick, turned out to be noisy injector. Quote
lugorobert Posted May 8, 2014 Author Report Posted May 8, 2014 Harbor freight sells mechanic stethoscopes super cheap, other guys put a screwdriver to their ear (I have longer hair so that close to moving parts is bad) anyway that can really help to pinpoint sounds. I thought I had lifter tick, turned out to be noisy injector. I used a screw driver to get a good listen, it sounds as if it is coming from the supercharger impellers definitely not from the nose, its kind of a click sound but very faint it is still there if i bring the rpms up to 800 or so but dissipates around 1000. Quote
Euro Posted May 8, 2014 Report Posted May 8, 2014 I think I know what you're talking about. It may be the injectors as well, I've heard of them having a slight "tick." I have the same sound in my car, but I chalked it up to normal noise. I don't think you need to worry. Unless of course you hear it get audibly louder. Quote
Michael Savage Posted May 8, 2014 Report Posted May 8, 2014 The Bosch 3.8 SC injectors make a very large tick pull one and jump it using a fire alarm battery and you'll hear it Quote
lugorobert Posted May 8, 2014 Author Report Posted May 8, 2014 Yeah the more and more videos i listen to of these cars running i can hear it in other motors. i just get paranoid and i am very picky haha. i have a modular pulley system on the way to drop to a 3.5 pulley a u-bend delete, 160 drilled thermostat, ngk tr-6 plugs, and a 3.5in tensioner pulley and i dont want anything coming apart from the added boost/power. thanks for all your help guys. another quick question, the zzperformance sc oil says its the perfect amount, but i read all over that the oil should come to the bottom of the threads on the fill hole, i added the whole 6oz bottle of oil but it definitely does not come up to the fill plug, should i add a little more? Quote
Imp558 Posted May 8, 2014 Report Posted May 8, 2014 Our FAQ has it as bottom of the threads. http://www.w-body.com/showthread.php/21843-Eaton-M90-Supercharger-Oil-Change Quote
