mellowoutbro Posted May 23, 2015 Report Posted May 23, 2015 There was a tiny puddle of fresh oil at the edge of the plenum and my throttle body was literally caked up with crap. On the inside. Sent from my iPad using Tapatalk Quote
RobertISaar Posted May 23, 2015 Report Posted May 23, 2015 normal. not great, but not all that damaging either. make sure your PCV system is operating properly and use a proper viscosity oil with a low NOACK score and it won't be an issue. Quote
mellowoutbro Posted June 11, 2015 Report Posted June 11, 2015 I have a 94 gp. 3.1 bone stock. Is it beneficial to put a 180 degree thermostat? Quote
RobertISaar Posted June 11, 2015 Report Posted June 11, 2015 no. they're actually questionable on modified engines unless you happen to go through...... most of the engine, changing bearing gaps among other specifications to better suit a colder running engine. Quote
George Posted June 12, 2015 Report Posted June 12, 2015 Engines run more efficient at higher temps, MPG wise, mostly for fuel atomization and more complete combustion I believe. A lot of times aftermarket tuner companies will recommend lower temp thermostats (160 deg) in an attempt to lower cylinder temps reducing the chance of pre-ignition (knock retard) due to advanced timing and fuel mixtures changes to get optimum performance. Quote
RobertISaar Posted June 12, 2015 Report Posted June 12, 2015 aka: Band-Aid for a bad design or unintended form of operation. it does lower incoming air temps for a more dense air-charge, but at what cost? cold-weather operation deteriorates, emissions suffer(with a possible exception to NoX, but depending on calibration changes, not always), engine wear accelerates.... literally one minor good effect vs many major bad ones. more efficient combustion helps literally every aspect of engine operation, more power is made for a given amount of fuel. and before cold-air intakes come up(again?), unless you have a TGP, you have a more than adequate filter/tubing setup that already draws cold-air behind the headlamp. for whatever stupid reason, someone at GM/McLaren got one hell of a joke filter into production for the TGPs. i'll let that one pass for "needs more air" rather than "want more sound", which is what a CAI/SAI does otherwise. Quote
mellowoutbro Posted June 12, 2015 Report Posted June 12, 2015 So no sense for me to swap my 195 thermostat to a 180. Again all stock l82 Quote
RobertISaar Posted June 12, 2015 Report Posted June 12, 2015 GM engineers aren't dumb.... occasionally, they get overruled by accountants, but the engine is designed to operate between the factory thermostat temperature and the factory fan 1 on temperature(225ish, going off of memory), though keeping thermal cycling(bouncing between those two temperatures) to a minimum isn't a bad thing. Quote
George Posted June 13, 2015 Report Posted June 13, 2015 aka: Band-Aid for a bad design or unintended form of operation. it does lower incoming air temps for a more dense air-charge, but at what cost? There may be a slight reduction in intake air temp due to the 35 deg cooler intake manifold and intake plumbing which may be part of the claims for BIG HP gains. Seems like that was a Hypertech thing in the early '90's. I got a Fastchips brand chip for my '89 Lesabre T-type N/A 3800, back in '04, claimed +13HP at the wheels (which you could feel going up the canyons) with no need to go to lower temp thermostat. I tried a 180 deg t-stat anyway and all I noticed is that it took 35 min of driving to get the passenger compartment up to temp instead of 20 min at 10 deg below 0. Sent from my iPhone using Tapatalk Quote
George Posted June 13, 2015 Report Posted June 13, 2015 So no sense for me to swap my 195 thermostat to a 180. Again all stock l82 No advantage with stock setup, especially if you want to stay warmer in the winter time. Sent from my iPhone using Tapatalk Quote
George Posted June 13, 2015 Report Posted June 13, 2015 and before cold-air intakes come up(again?), unless you have a TGP, you have a more than adequate filter/tubing setup that already draws cold-air behind the headlamp. for whatever stupid reason, someone at GM/McLaren got one hell of a joke filter into production for the TGPs. i'll let that one pass for "needs more air" rather than "want more sound", which is what a CAI/SAI does otherwise. I agree, if your engine only flows 600 CFM and the factory filter is good for 650 CFM there is no point in putting on a filter that flows 800 CFM. Although I think there is some merit to using a ram air set up. I added an extra snorkel to a factory large filter Chevy truck housing that I put on top the 750 CFM Rochester Quadra junk carb in my old '82 T/A with a mild 400 inch small block. I added the dual snorkel ram air with a factory paper filter that ran to 2 funnel type scoops next to the fog lights, went from 91 to 100 octane fuel, bumped the timing from 12 -16 deg before TDC and the car went from 13.23 to 12.81 in the quarter. Granted, most of that was better fuel and more timing. Maybe I just like Ram-Air? Then I added a bigger cam and went 12.47 at 109.5 MPH.[emoji15][emoji3] Sent from my iPhone using Tapatalk Quote
RobertISaar Posted June 13, 2015 Report Posted June 13, 2015 There may be a slight reduction in intake air temp due to the 35 deg cooler intake manifold and intake plumbing which may be part of the claims for BIG HP gains. Seems like that was a Hypertech thing in the early '90's.I got a Fastchips brand chip for my '89 Lesabre T-type N/A 3800, back in '04, claimed +13HP at the wheels (which you could feel going up the canyons) with no need to go to lower temp thermostat. I tried a 180 deg t-stat anyway and all I noticed is that it took 35 min of driving to get the passenger compartment up to temp instead of 20 min at 10 deg below 0. Sent from my iPhone using Tapatalk I know all about hyperjunks.... the 85 IROC had one, I pulled the calibration off of it and it looks terrible compared to a stock calibration. that one wanted a 160 thermostat as well, so much so that they quit changing tables above that temperature. Quote
George Posted June 13, 2015 Report Posted June 13, 2015 Maybe the 160 deg t-stat thing was more out of laziness than necessity? Quote
mellowoutbro Posted June 29, 2015 Report Posted June 29, 2015 Can I install the 96+dog bones on my 94. It has the ones with the round bushings on each end Sent from my iPad using Tapatalk Quote
Psych0matt Posted June 29, 2015 Report Posted June 29, 2015 Can I install the 96+dog bones on my 94. It has the ones with the round bushings on each end Sent from my iPad using Tapatalk If it's the same engine you should be able to, only I don't really see how that would do anything Quote
mellowoutbro Posted June 30, 2015 Report Posted June 30, 2015 I hear the new ones have a bushing that can be flipped to make it stiffer Sent from my iPad using Tapatalk Quote
Torque_Effect Posted June 30, 2015 Report Posted June 30, 2015 What's the benefit of dog boning the torque struts? Sent from my LG-D800 using Tapatalk Quote
Imp558 Posted July 1, 2015 Report Posted July 1, 2015 90* flipped torque strut bushings aren't as rigid as a good pair of the dogbones you already have, if you really want something FIRM look in the for sale section at the GOT2BGM dogbones with poly bushings. Quote
mellowoutbro Posted July 27, 2015 Report Posted July 27, 2015 Im looking for a 94 95 dic any one know where to get one? Quote
Jim_rockford_007 Posted January 24, 2020 Report Posted January 24, 2020 please for the love of god fix the retarded ass broken images caused from Photobucket trying to extort money from people by holding their images hostage. Quote
Psych0matt Posted January 25, 2020 Report Posted January 25, 2020 Unless you can get every single person that’s ever posted in this thread to go to Photobucket and download all the pictures, reupload them somewhere else, figure out which ones went to which post, and updates all the links, that’s probably not gonna happen. Quote
94 olds vert Posted January 25, 2020 Report Posted January 25, 2020 I thought by uploading pictures on photobucket they would be preserved for a long time. It wasnt long enough apparently. Psych0matt 1 Quote
