RobertISaar Posted April 11, 2015 Report Posted April 11, 2015 the two EGR systems are VERY different. the 95-earlier is a 3-solenoid "digital" scheme with 8 different combinations of flow with no feedback to the ECM in terms of pintle position. the 96+ is a "linear" setup that uses a single solenoid with a feedback sensor to dial in a desired amount of flow. that's not accounting for the different way that they mount or have their EGR tubes ran to them either. I'm looking into developing a code patch to allow the 94-95 3100 PCM to control a linear EGR valve, but I don't know if i'll go through with it or just buy/make an adapter. Quote
mellowoutbro Posted April 11, 2015 Report Posted April 11, 2015 I know you can get an adapter from mms for like 60 bux. Is there any cheaper ways to do it Quote
19Cutlass94 Posted April 11, 2015 Report Posted April 11, 2015 No. Just get the adapter. Sent from my iPhone Quote
19Cutlass94 Posted April 11, 2015 Report Posted April 11, 2015 $60 is not a lot of money. If you can't afford it, try and look on the for sale or on ebay for a used one. Quote
mellowoutbro Posted April 14, 2015 Report Posted April 14, 2015 Does anyone know where i can find a guide to installing a 3400 lim-3500 uim onto my 94 gp se Quote
RobertISaar Posted April 15, 2015 Report Posted April 15, 2015 mix this: http://wot-tech.com/index.php?page=94-99-3100-large-port-swap with this: http://wot-tech.com/index.php?page=swapping-a-3500-upper-onto-a-3400-engine I'm considering doing it myself. Quote
mellowoutbro Posted April 17, 2015 Report Posted April 17, 2015 Does anyone know what the difference is between the plastic and aluminum valve covers on the 3100 sfi. If there is any benefit to swapping Sent from my iPad using Tapatalk Quote
RobertISaar Posted April 17, 2015 Report Posted April 17, 2015 the plastic ones(if there are any left) were prone to leakage. Quote
mellowoutbro Posted April 17, 2015 Report Posted April 17, 2015 Mines a 94. Its leaking all over. Ok. So, swapping to aluminum would be ideal Quote
rich_e777 Posted April 17, 2015 Report Posted April 17, 2015 Those plastic ones like to crack around the bolts some fro a later model 3100 or 3400 are a direct swap. Swapping mine out for some from a 2004 Monte Carlo was the first mod I did to my car. It leaks a little from some of the worn out rubber grommets though so I might swap them out again soon. Quote
mellowoutbro Posted April 29, 2015 Report Posted April 29, 2015 I have an ac question. My ac is to low on freon and wont come on. Can i just add some freon or do i have to get it serviced Quote
RobertISaar Posted April 29, 2015 Report Posted April 29, 2015 refrigerant doesn't just disappear.... it leaked out at some point, so you do have a leak somewhere in your system, how fast it disappears is a good question. if you have a V5 compressor, it is almost certainly at least one of the two "belly" seals that are used to seal the 3 major portions of the case together. Quote
mellowoutbro Posted April 29, 2015 Report Posted April 29, 2015 In lamens terms...get it serviced Quote
RobertISaar Posted April 29, 2015 Report Posted April 29, 2015 for long-term results, yes. recharging it without finding the leak(don't use refrigerant with "leak sealer" in it, you will instantly have a rather poor reputation with anyone that uses a recycling/reclaiming machine) may last a year or two.... or just a couple of hours, in my case. Quote
mellowoutbro Posted May 1, 2015 Report Posted May 1, 2015 I noticed the 96 gtp sits lower in the front than mine does(I have a 94). Can I get some springs from a gtp and slap em on mine Sent from my iPad using Tapatalk Quote
mellowoutbro Posted May 12, 2015 Report Posted May 12, 2015 I just cut out my non hud dashpad. I have no idea what i can do as far as trim so it doesnt look all ghetto. Any ideas? Quote
rich_e777 Posted May 13, 2015 Report Posted May 13, 2015 I just cut out my non hud dashpad. I have no idea what i can do as far as trim so it doesnt look all ghetto. Any ideas? They sell dash covers that will lay over the top of the existing dash. Or maybe 4 pieces of rubber hose cut with a slit down the side and 45s cut on the ends to act as a trim. Do you have a hud unit to put into it? Quote
mellowoutbro Posted May 13, 2015 Report Posted May 13, 2015 Hue is in. I had a dash mat. Ugliest thing ever lol Sent from my iPad using Tapatalk Quote
mellowoutbro Posted May 22, 2015 Report Posted May 22, 2015 Thats the in side of my plenum. What can cause this Quote
92cutlass3.8 Posted May 22, 2015 Report Posted May 22, 2015 Thats the in side of my plenum. What can cause this I would think a combination of the pcv and the egr. Quote
Michael Savage Posted May 22, 2015 Report Posted May 22, 2015 Thats the in side of my plenum. What can cause this Make an oil catch can like this Run a 2nd hose to the bottom on the jar from the metal valve and the oil will settle in the jar instead of the manifold. Put brass wool in it to filter better, or just buy one online. If oil quickly builds up, ide suggest replacing the metal PCV itself because they can go bad, GM says to replace them every 100k to keep it running proper. it's $2.99 at Orileys and part number 299. Sent from my iPhone using Tapatalk Quote
RobertISaar Posted May 23, 2015 Report Posted May 23, 2015 i would call that buildup "normal operation". that isn't bad, but it could be better. you could think of it as a secondary filtration system, any dirt/dust that otherwise would have bounced around in the intake before being sucked into a cylinder instead hits a film of oil and is trapped there. Quote
