94 Olds Cutlass Convertible Window
The small triangle window attached to the convertible roof has the trim and weather stripping coming off it. This has left a gap between the rear window that goes up and down the small triangle window which of course is allowing the rain to pour in. I need to get this fixed. Does anyone know how to get the window out so it can be replaced?
The only fix i know is to replace it.... window and all. Best luck finding one. i grabbed one set while in chicago, wish i grabbed more.
Urethane will be the cheaper option. It's the same thing.used to seal windshields.
You would have to make your own weather stripping that way. It's gonna be a bit.hard because when it dries it sticks to everything so put painters tape where you want the window to move and when it dries, peel off slowly
Sent from my HTC using Tapatalk.
