Turn signals blink when turning left but not right
A strange issue just started happening. My turn signal works fine and blinks when turning left. However, it stopped blinking for a right turn...unless I put additional pressure on the switch. If I can get the blinker started most of the time it stays on as I am turning right. Has anyone else run into this? How do I fix it?
Thanks,
Tom
Thanks,
Tom
I'm having the same problem with one of my cars and I traced it to the Turn Signal Switch which has brass contacts inside which wear out over time and no longer make contact. Here is a Link to a DIY Repair.
http://tss.likeabigdog.com/
Yep, sounds like the multifunction/turn signal switch is failing
Yup, been there done that. nitehawkjcb got it. I think they are about $40 at Autozone, could be wrong its been awhile. I didn't have to remove my steering wheel to change mine IIRC.
I had to pull my wheel also. But we're both 5th gen Montes. ;)
In other words we're the resident badasses right ;)
