Cali boi Posted April 22, 2014 Report Posted April 22, 2014 Hey guys its been a long time. I have a question on some of the shift kits I found and want some input you guys. So I found for the 4t65e tranny was the thrasher, trans go, and the ZZP. I not sure on which i should get so I did a bit of research and found that the trans go, and the thrasher shift kits are both the spring type and the ZZP is a valve type (not to sure what to call it). So seeing that i was thinking if or will it be ok to run the thrasher or trans go with the ZZP. And if not a good idea which would be the better one to go with.. Sent from my iPhone using Tapatalk Quote
Schurkey Posted April 22, 2014 Report Posted April 22, 2014 TransGo has been in business for decades; and have a positive reputation with professionals who work in transmission shops. http://transgo.com/ Quote
Andrew Posted April 27, 2014 Report Posted April 27, 2014 1 or the other, not both. I would recommend the spring kits over ZZPs & Wbodystore spacers every time. Intense racing has a spring kit too for $100. Quote
