davidmorris1046 Posted March 31, 2014 Report Posted March 31, 2014 3.4 1993 vert stopped running as if it were running out of gas. half full tank at the time, starting spray started the car. I changed the fuel filter, better but still acts like its out of gas. Full tank now. after changing the inline fuel filter, I bled the air out of the lines. Car started with starter spray. Settles down after awhile but sputters if you step on the gas. Depression of the Bled valve indicates more ait in the system. No visual leaks. Where is the air comming from? Quote
95 vert Posted April 1, 2014 Report Posted April 1, 2014 Sounds like the fuel pump. Check the fuel pressure Quote
KarenL2888 Posted April 1, 2014 Report Posted April 1, 2014 mine did that when the vac hose disconnected. Reconnecting it doesn't reset the computer and it sucks too much air til it is reset Quote
davidmorris1046 Posted April 5, 2014 Author Report Posted April 5, 2014 mine did that when the vac hose disconnected. Reconnecting it doesn't reset the computer and it sucks too much air til it is reset Karen, Which Vac hose? Quote
KarenL2888 Posted April 5, 2014 Report Posted April 5, 2014 http://www.w-body.com/showthread.php/77513-what-is-this Quote
