matt9207 Posted March 29, 2014 Report Posted March 29, 2014 Ok so my car decides to "pop" out of gear when I come to a stop. There's no slippage of any kind while driving just coming to a stop. I have to kick it up to neutral and back down to drive and I feel it go into gear like normal and can drive without incident until I stop again. I've replaced the modulator and trans filter. Do you think it can be line pressure not high enough or just internal damage? Like I said above, there is no slipping when the car is driving. Just when I make a complete stop. Also, there are times it won't do it at all I can drive all day without incident. Any help would be great. Thanks in advance. Quote
Hairdo12 Posted March 30, 2014 Report Posted March 30, 2014 Internal leakage in the valve body. Try driving in 3 rather in OD and I bet the symptoms do not occur. A bottle of TransX fixes this every time after about 15 miles of driving. I've seen this a handful of times on the 4t60 and always had favorable results. A Trans shop will try to sell you a rebuild in a second. Quote
matt9207 Posted March 30, 2014 Author Report Posted March 30, 2014 What happens if I drive in 3 and it still does it? What would I need to do then Quote
Hairdo12 Posted March 30, 2014 Report Posted March 30, 2014 Hmm I'm not too sure, that has worked 8 of 8 times. I'd dump the TransX in anyways if it did act the same in 3. The tranx restored full function with OD. Quote
matt9207 Posted March 30, 2014 Author Report Posted March 30, 2014 I'll give it shot and report my results afterwards Quote
matt9207 Posted April 21, 2014 Author Report Posted April 21, 2014 TransX worked great when I put it in the trans. Made it to Florida and back 1500 mile round trip. Also a couple weeks after getting back but recently the exact same symptoms have returned. If anyone can help on what I should do would be greatly appreciated. Quote
