PTAaron Posted March 23, 2014 Report Posted March 23, 2014 Putting my engine back together right now on my '94 Cutlass Supreme 3.1L - and the last time we re-assembled it my father in-law put this section back together... The module that mounts on the same studs as the ignition coils - has a red and blue connector on it, a vacuum connection in the middle, and another vacuum line under that. I'm trying to figure out what is supposed to connect to that center fitting? Pictures below will clarify... I don't remember disconnecting anything from it - so I'm not sure what is supposed to connect to it! Thanks! Quote
RobertISaar Posted March 24, 2014 Report Posted March 24, 2014 that is the carbon cannister purge solenoid. one vacuum line will run to the engine, another will come up from near the brake lines and run over to the solenoid. Quote
PTAaron Posted March 24, 2014 Author Report Posted March 24, 2014 Great, thanks!! Okay, so the line to it must be one of the lines I have sitting off to the side with the other parts that have to go on still. I just got worried when I didn't see an appropriately sized vacuum line to hook to it. Quote
