Guest Posted November 3, 2002 Report Posted November 3, 2002 I have a question for those of you with Oldsmobiles that have the digital ATC (mostly for those of you that the car came with it, not that you put it in yourself). DOES YOUR A/C COMPRESSOR STAY ON ALL THE TIME????? It does not matter if I have it on AUTO, DEFOG, DEFROST, BI-LEV, UPPER, LOWER, FAN ON HIGH OR LOW. My compressor does not turn off unless I turn the car off, turn the unit totally off, pull a fuse or the relay. I know that Brian P. is haveing the same problem. I was just wondering if it is suppose to do that, or if I have something messed up. Taylor Quote
msvestka Posted November 3, 2002 Report Posted November 3, 2002 I have a question for those of you with Oldsmobiles that have the digital ATC (mostly for those of you that the car came with it, not that you put it in yourself). DOES YOUR A/C COMPRESSOR STAY ON ALL THE TIME????? It does not matter if I have it on AUTO, DEFOG, DEFROST, BI-LEV, UPPER, LOWER, FAN ON HIGH OR LOW. My compressor does not turn off unless I turn the car off, turn the unit totally off, pull a fuse or the relay. I know that Brian P. is haveing the same problem. I was just wondering if it is suppose to do that, or if I have something messed up. Taylor YES! My CS has exhibited this ever since I owned it. It only seems the A/C compressor will NOT run when the outside temp is below freezing. Quote
gmrulz4u Posted November 4, 2002 Report Posted November 4, 2002 I second that... My AutoXray shows that the A/C Compressor goes ON whenever I turn my Electronic Climate Control ON...not matter what... Quote
88Intl Posted November 4, 2002 Report Posted November 4, 2002 Does the compressor clutch open on hard acceleration? Quote
